jack 0 Posted February 6, 2010 Hi, I fitted a new bonnet cable today but it is very tight. If I pull the lever I think I will break the clip. What have I done wrong when fitting it? Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 6, 2010 check the routing of the cable, if there is a kink or mis routedit will make the cable not move freely inside, also inspect the latch assembly under the bonnet and work it manually and lots of wd40 it could be partially seized! remove work clean and reinstall, to make sure it isnt seizing or binding :D Quote Share this post Link to post Share on other sites
jack 0 Posted February 6, 2010 Thank I'll give that a go. Quote Share this post Link to post Share on other sites
