carrots 1 Posted February 14, 2010 hi all i am on my 4th battery in 4 months,had alternator checked twice and its fine.could it be sh-t batterys or the car killing um :help: :help: Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted February 14, 2010 Ouch! What are the symptoms? To kill a battery that fast it would either need to be overcharging, or being drained flat every night. When you had the alternator checked what voltage was it putting out? Quote Share this post Link to post Share on other sites
carrots 1 Posted February 14, 2010 both testers said the alternator was giving the correct charge.the battery is fine for about 3 weeks then they die so dont think they are being drained that much over night overwise they would be dead in a week.its very strange.it started fine today tho Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 14, 2010 Are the batteries under guarantee ? Quote Share this post Link to post Share on other sites
carrots 1 Posted February 14, 2010 yer they are which is good i work for unipart.just want the problem sorted.if its the car that at fault i want to put it right. Quote Share this post Link to post Share on other sites
Skills 0 Posted February 14, 2010 I was having the same problem but never got round to changing the battery just kept charging it. In my case there was either something wrong with the stereo I fitted or something wrong with the way I fitted it. Put the original sony one back in and it's been fine for the last 2 months. The head unit was working fine with no problems at all but must have been draining charge overnight. Quote Share this post Link to post Share on other sites
carrots 1 Posted February 14, 2010 i had thought about the stereo draining it,but why is it fine for a few weeks then it happens Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 14, 2010 I had a google on your behalf,hope it helps http://wiki.answers.com/Q/What_kills_th ... he_battery Quote Share this post Link to post Share on other sites
carrots 1 Posted February 14, 2010 cheers i will read what it says Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted February 14, 2010 Are the batteries actually dead, as in won't hold a charge any longer? Or are they just flat? In this weather if they go flat overnight they could freeze, and then they won't recover. It could be a drain from something. I had a problem where it would randomly go flat overnight and it turned out to be a dodgy ignition switch leaving the fan on. That was in the summer tho so the battery was fine after a good charge. Quote Share this post Link to post Share on other sites
carrots 1 Posted February 14, 2010 ive taken the batterys to work put um on the tester and they come up as unserviceable. Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 14, 2010 On the days that the batteries had "died" was it a cold/frosty day ? Meaning if you had a current drain, the frost/cold could have killed the batteries off ! Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted February 14, 2010 I reckon they've discharged and frozen then. Time to start looking for current drains I think... Quote Share this post Link to post Share on other sites
carrots 1 Posted February 14, 2010 that sounds like its going to be tricky Quote Share this post Link to post Share on other sites
gogsboy 0 Posted February 19, 2010 I had unipart battery, was suppsoed to be one of the better ones with big warranty but it was rubbish. Got a Bosch Silver from Costco for around £50 with 5yr warranty if I recall and it's made a big difference. Another drain issue I've heard of is that some cars are fitted with tracker and once the tracker battery is totally dead, it can suck juice from the main battery. Quote Share this post Link to post Share on other sites
carrots 1 Posted February 19, 2010 hi mate when did you buy the unipart battery and how long did it last,was it a 4 year un.i work for unipart :lol: Quote Share this post Link to post Share on other sites
