lycara 0 Posted February 21, 2010 Had a quick search couldnt find the answer I was looking for. I have some porsche wheels 7x15 not sure what tyre to run. I was thinking 195/45/15 would that be ok or should I stick with the 205/50/15? :confused4: Quote Share this post Link to post Share on other sites
dukest 0 Posted February 21, 2010 well if the wheels are wider than normal and you run standard tyres then they'll be stretched, if you run narrower tyres then they'll just be more stretched? going 45 profile as well will throw out your speedo even more than 195/50 will. not sure anyone can give an answer on what to go for apart from you and how you want them to look?! :shrug: Quote Share this post Link to post Share on other sites
lycara 0 Posted February 21, 2010 Thanx want them a little stretched. Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted February 22, 2010 195 50 15 works nicely on a 7x15 - thats the right diameter for the 'rado. But, if you want them stretched then go for the 185 55 15 which is the factory size for the 6.5x15 from the 16V. 194 45 is too small for the Corrado IMO unless you want the Euro cotton-reel-wheels look. Quote Share this post Link to post Share on other sites
