greasegriff 0 Posted February 25, 2010 Probably a very simple answer but I have upgraded my front brakes to the 288mm variety. What discs and pads do I need to replace what is now on these? I've been looking an Red/Green Stuff pads as a compromise on price/quality. What car should I be matching these too? A Mk 4 Golf? Is that what the 288mm calipers would have come from? Also, not really sure what discs I need. Any help from knowledgeable people would be great! Quote Share this post Link to post Share on other sites
KADVR6 0 Posted February 25, 2010 reds with OE discs are very very good. Quote Share this post Link to post Share on other sites
greasegriff 0 Posted February 25, 2010 reds with OE discs are very very good. So what am I getting? These (DP3981C) http://www.ebcbrakesdirect.com/car/parts_pad.asp?part=pad&make=VOLKSWAGEN&model=Golf&year=2%2E8+VR6+%2892%2D95%29# And are 288mm VW discs just generic? Quote Share this post Link to post Share on other sites
greasegriff 0 Posted April 1, 2010 Still struggling with this guys... I'm not sure what calipers I have. Are Mk3 and Mk4 Golf calipers basically the same in that you can put the same pads & discs on both? Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted April 2, 2010 Where did the calipers come from? What make are they? Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted April 2, 2010 The 288mm fronts "generally" come from a late Mk3 Golf VR6. Ian. Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted April 2, 2010 Or the MK4, or certain Ibiza's, Leons, Toledo's. Lots of variants really.... A couple of pics would help. Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 2, 2010 reds with OE discs are very very good. So what am I getting? These (DP3981C) http://www.ebcbrakesdirect.com/car/parts_pad.asp?part=pad&make=VOLKSWAGEN&model=Golf&year=2%2E8+VR6+%2892%2D95%29# And are 288mm VW discs just generic? no you will need 95-98 golf mk3 ones assuming they came off a mk3 golf. same part also listed for early mk4 1.8t so id assume this is most likely what your after. http://www.ebcbrakesdirect.com/car/parts_pad.asp?part=pad&make=VOLKSWAGEN&model=Golf&year=2.8+VR6+%2895-98%29 the early vr6 used 280mm, different calipers etc. offsets could be different on the discs. worth having a look at the part number stamped on top of your caliper (should be ate) just to be certain. Quote Share this post Link to post Share on other sites
V-Dubstar 0 Posted April 2, 2010 Yeh but sod that - if ur getting EBC's go to http://camskill.co.uk/ u can get both sets (rear and front) or the reds for £100 delivered, and the green's for £86 delivered! Quote Share this post Link to post Share on other sites
greasegriff 0 Posted April 2, 2010 Right, I stopped being lazy and messaged the guy I bought them off. Late Mk 3 VR6 Golf apparently. So I'll be on the hunt for EBC Redstuff pads and drilled & grooved discs. Let the search begin! Quote Share this post Link to post Share on other sites
dukest 0 Posted April 2, 2010 if you mean surface driled like the ebc discs then thats cool but dont go looking for fully drilled - grooves are all you need. Quote Share this post Link to post Share on other sites
greasegriff 0 Posted April 3, 2010 I'm not sure what I meant so thanks for the advice! Quote Share this post Link to post Share on other sites
