Bruno
Prep'g for OBD2 - Removing the Servo, etc- advanced guidance
Hi. Well its about to happen. I've had enough of stalling at lights and poor diagnostics. The change to OBD2 on my VR. I've read most of the threads that refer to this, and also Dennis' thread on Corrado Ca. It seems that apart from starting with the right bits, there are few hiccups along the way:
1. Removing and replacing the Servo.
2. Recalibrating the Throttle Boddy.
3. Proximity to the ignition pick up coil with the appropriate key.
Bentleys sheds little light on the issues with (1), and wouldnt cover (2), and (3) seems relatively easy to address. Coming up with a good, well spliced and wrapped loom is not an issue for me. So....
------are are there issues which I need to watch out for?
Any advice on how to handle (1) and (2) and the rest you can think of?
1) removing the servo is a pian,you have to remove the master cylinder then get under the dash remove the clip that holds the servo to the pedel and then the four M8 nuts then work the servo out while muttering "how the fuck does this come out!!" :lol: its getting it back in thats the pain,you need to make sure the new loom is well tucked away as the servo will foul it and you will never get it back in!
2) All you do to calibrate the throttle is switch the ignition on and wait for the throttle to cycle and you will hear it aswell as a light hum...thats it! also if it does all that you have wired everything in right!
3) dont know as i never fitted it as the C2 software removed this for me :tongue:
Some usefull guides if you dont have them already mate.
http://www.a2resource.com/electrical/CE2.html
http://www.corrado-club.ca/forum/viewto ... sc&start=0
http://www.the-corrado.net/.archive/forum/viewto ... conversion
http://forums.vwvortex.com/zerothread?id=3914622
you also might encounter a problem with your wipers not working,i found one of the plugs from the engine bay loom had to have two wires swapped over and also i had to bridge over a wire for the secondary cooling pump to work.
Good luck.
