VR6_ROB 0 Posted March 9, 2010 how do I get the ecu out I need it out tonight feels solid I dont want to break anything rob Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted March 9, 2010 Remove the scuttle cover (you need to prise the clips off- take your time, as it rips quite easily). Then, you need to remove the engine loom plug. It has a slider which holds it onto the ecu. Pull the slider towards you, then the plug will just pull out. You may need to prise the slider forwards with a flat head screwdiver, as they can be difficult to move if they haven't been done before. Then you're left with 2-3 cross-head screws- can't remember how many are on each side, but it's pretty obvious. Once these are undone, it should just slide off it's metal frame. A bit of manouvering is required to get it out of the scuttle. Done :) Take your time and be careful not to damage the plug pins/loom ;) Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted March 9, 2010 cheers bud I will go have a go at that now Quote Share this post Link to post Share on other sites
