Woodsy_is_back 0 Posted April 4, 2010 Having taken apart my engine I have 2 of my injectors that have cracked casings and are probably damaged (due to flying metal content during blow up!) - need to replace them plus t'other 2 . . . Has anyone got any reccomendations of any performance replacement injectors that they use or is a VAG part that I need? Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 4, 2010 according to Euro Car Parts website, your car is a blue 1990 KR 16v, so you'll be wanting K-jet 16v injectors then :) and they're 36.40 each, there's no 'performance' K-jet injector, just the original bosch ones are fine. you could try some second hand ones, but I was chatting about this today and apparently they're well past their best after 80K and can't be cleaned Quote Share this post Link to post Share on other sites
Woodsy_is_back 0 Posted April 5, 2010 Wow! :notworthy: Yep, that's the fellas and seeing as they have done 115,000 I think it's time for a new set broken or not - was reading up in http://the-corrado.net/.archive/forum/viewtopic.php?f=1&t=89364 about using Merc injectors cos as you say K jet have a poor spray pattern - will replace with the same :thumbleft: Quote Share this post Link to post Share on other sites
