skinnyman9000
Brake pedal vibration
Getting some vibration thru the brake pedal, getting worse over the past fortnight. Discs and pads looked fine when i had the mot done. The braking ability isn't getting any worse (still as crap as ever).
What's the likely cause and cure?
heavy braking can cause the discs to warp, and the vibration can be felt through the pedal and steering wheel, prob your front discs! rear disc can also fade, to check this you can carry out a brake disc runout, using a dial test indicator.
