John-M
Brake Balance valve - service or replace ??
My Brake Balance/Bias Valve ( located on the rear cross-member ) has a small leak. Not serious, but not something I want to leave ... ...
Is it a serviceable item ? Or is replacement the only option ??
Replace. Save it for when you do the rear axle bushes as it has to be cut off anyway, 9 times in 10, due to corroded mounting bolts and / or corroded brake pipe unions. A new one is about £70
Was quoted £130 plus vat a couple of days ago :( :(
