Gareth_16V 0 Posted April 14, 2010 Hi All, I'm replacing the top mounts on my '95 valver, which according to the diagrams in the Bentley manual has top mounts like a VR (don't know if this is due to it being a very late one, 50-S-002137). Granted I'm not using genuine top mounts, which I know have been slated on here, but better a new short-lived part than a worn out original - FOR NOW! I have used the search, but can't find the answer to an assembly question I have. The assembly sequence according to the manual is as follows (starting from the bottom up):- Spring on damper Spring top plate on spring Top mount bearing on top of spring plate Washer faced nut on top of bearing Rubber for top mount on top of nut and bearing. But when I do it like this the rubber part of the top mount does not seat on the bearing properly. If I change the order to:- Spring on damper Spring top plate on spring Top mount bearing on top of spring plate Rubber for top mount on top of bearing Washer faced nut the nut is caught in the top mount rubber and the damper rod turns easier than the rubber on the top mount bearing. I'm obviously missing something fairly fundamental - I don't think I'm missing any parts as the diagram doesn't show any more bits than I've got. Is it just that the hole in the top mount needs relieving slightly to clear the nut? Or have I got the wrong model of top mount? Thanks in advance, Gareth Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 14, 2010 i know the exact thing you mean, and i put the nut on after the rubber donut went on, once the strut was back on the car and the car back on the ground it all seemed ok Quote Share this post Link to post Share on other sites
