dadoogie
Power steering part snapped.
From what i can work out its the tensioner arm, its quite a substantial peice of metal thats snapped off. it's on the side of the belts and pulleys, the powersteering pump hasnt fallen off and the belt hasn't started to squeel.
Im still humming and harring about what this peice of metal is, wish i had a picture will try and get one when im home this weekend, could anyone tell me what this thing is? without pictures. Thanks.
Edit: Picture might be relevant.
bit confused by your post, but in that pic is the mounting arm for the pump (3 bolt holes around the curve) this hangs from the alternator bracket and swings the pump to tension
and on the left is the arm for the tensionner bolt, this bracket bolts to the side of the block
