coullstar
Yellow temp sensor position
Is my yellow temp sensor sitting right in the photo. The other two are flush with the housing yet the yellow sensor is sitting more proud of the housing?
Also anyone know the part number for the o-ring as its leaking?
Did my thermo recently and yes I think that is correct, there should be a clip holding it in anyway.
O-ring part number - N90316802
Not 100% sure - will try to check tomorrow (if I'm going to the place I work on the corrado) - but I *think* it's supposed to sit as the 2 others.
Looks normal then plus I think its cured itself. This cars great, it fixes itself.
Whats the brown one for by the way? Only ever seen yellow, blue and black.
I think the brown is a temp sensor used to air-con (IIRC). The yellow one have been replaced by a black one I think (don't think one will get a yellow one from VW today).
