JMC
Early to late foglight and demister wiring question
I have a late foglight and demister loom, and the corresponding late switches which I'm wanting to fit to my G60. Anyone know whether these are a straight swap for the early setup, or does anything else need rewiring?
Fairly sure it's a straight swap if you have the loom too.
What you could also look at is swapping the plugs over at the switch end using the pin tool and just match the layout of the later loom.
I have the loom as well as the switches, so basically was wondering whether it would swap straight over. Good to hear that's probably the case :D However I ave a couple of other little centre consol jobs to do before then...
