MArrado 0 Posted May 10, 2010 Hi, I have a seized VR6 engine - about 85K on the clock - that was removed from my car. The cause and actual problem is undiagnosed and its far above my knowledge to investigate further. Didnt know if there would be any interest in this or how much it would be worth. Ive removed the coil pack and HT leads but everything else it there. Cheers, Max Quote Share this post Link to post Share on other sites
dukest 0 Posted May 10, 2010 £50? they're only worth £3-400 when running so if yours needs a gasket or a rebuild its almost scrap in money terms unfortunately Quote Share this post Link to post Share on other sites
MArrado 0 Posted May 10, 2010 might just weigh it in in that case - other than the coil pack and leads do you think there is anything else that is worth removing? thanks Quote Share this post Link to post Share on other sites
dukest 0 Posted May 10, 2010 it depends, if you're prepared to take it apart and investigate you might get more because you might find its a small specific problem and you could sell the head/block separately. it might all be knackered though.. i was just responding to you as it was - strip it to pieces and maybe its worth 100-150? Quote Share this post Link to post Share on other sites
MArrado 0 Posted May 10, 2010 okay, thanks for the advice. If its possibly worth more seperate i suppose it wont do any harm to dismantle it....plus it will be good fun...and you never know, i might learn something. Cheers...over and out. Max Quote Share this post Link to post Share on other sites
