Johnkerry 0 Posted May 10, 2010 Hi fella`s, Ive just put my newly re-built charger back on the car and i thought i would give it a spray of PTFE to loob it up, after i finished spraying i reliesed i had picked up the wrong can i used white Lithium grease it serves me right for not paying attention to what i was doing it looked the same when it was going in it wasnt till afterwards that i reliesed :cuckoo: Is this likely to cause any problems ?? It does say on the can Heavey duty, long lasting lubricant, water and heat resistant Quote Share this post Link to post Share on other sites
jaded2882 0 Posted May 10, 2010 :gag: unlucky. I'd just not start it and ring G-werks or Jabbasport to be sure. I wouldn't have thought a bit would do much damage but maybe would if you kept doing it, but I don't know enough about them Quote Share this post Link to post Share on other sites
JMC 0 Posted May 10, 2010 Er, chargers are very specific about the lube they need. As above I'd recommend talking to either Jabba or G-Werks before even thinking about running it. Quote Share this post Link to post Share on other sites
Johnkerry 0 Posted May 11, 2010 I spoke to G-Werks this morning and they told me as long as there is no silicon in the greece it will be fine, i checked the ingredients and there is no mention of silicon so hopefully all is ok.They told me that the reason silicon can be a problem is that it glazes the lamba probe. Quote Share this post Link to post Share on other sites
