TITAN
ENGINE ECU
Can anyone tell me will a VW Golf Rallye G60 Syncro ecu Mk2 Gti Driver ECU unit will work
on a 1992 corrado g60 ?? .
cheers
it depends... :?
Rallye golfs were a smaller capacity unit and often had different injectors to the Corrado G60 engines, so the map won't quite be right for a Corrado engine... It'll run, but it may either run rich, or lean at different points in the fuelling map and rev-range depending on which flavour engine/ECU the Rallye in question had (and there's a couple of flavours I know of!)...
The MK2 GTI ECU won't work as they're Digifant1 not Digifant2 as needed by the G60 engine... MK2 Drivers weren't injection, so won't have an ECU as such!
