EVANS1
central locking
Hi can anybody help me please,after finding the rod to undo my petrol flap,i now want to get down to the problem of why,the central locking doesn't work anymore and i have to open each door and boot with the key,any help would be appreciated,thanks.
i take it you have checked the fuses?
did you manage to sort it? just realised that if you're not familiar with the C you might miss where the CL fuses are cos they are not with the rest of the fuses. they are on their own just above the main fuse block.
i had the very same issue as you, check all the fuses in the block and all were good. only after taking both doors apart to try and find the problem did i realise that there were some more fuses hiding in the dash, which had blown :censored:
