bananawhip 0 Posted May 20, 2010 Fitting a new fan switch to a new rad, comes with a card washer already, shall I slap a bit of sealent on the threads or pop it in dry? Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 20, 2010 should seal fine with the washer, I've had pattern rads that need help from a bit of PTFE tape on the threads but not on OEM rads. Quote Share this post Link to post Share on other sites
bananawhip 0 Posted May 20, 2010 Quote should seal fine with the washer, I've had pattern rads that need help from a bit of PTFE tape on the threads but not on OEM rads. Thanks for that, it's pattern and a Neuspeed switch so might use a bit for good measure Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 20, 2010 Not the Neuspeed 70 deg stat I hope? It's too close to the warm-up fuelling switch over mate. The cold start / warm up map turns off at 70 deg water temp. With the 70 deg stat, it could end up staying in warm up mode for too long, or permanently over winter, causing over fuelling. Stock stat opening is 80 deg for this very reason :D Healthy VRs run at 3 to 5 degs above stat opening usually, so the standard stat is perfectly fine! Quote Share this post Link to post Share on other sites
bananawhip 0 Posted May 20, 2010 I was going to leave my standard stat in but fit the Neuspeed fan switch so they kick in a bit sooner Fan seems to get a bit caught out since fitting the VF, temps are higher then I'd like, might've been the nackered rad though You think that set-up will be ok Kev? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 20, 2010 Yep, never understood the point of low temp stats or fan switches - sure just a way of working round a problem that lies elsewhere in the system... Quote Share this post Link to post Share on other sites
Jim 2 Posted May 20, 2010 And in fact, after testing by DG Autotech (when I'd fitted a Neuspeed fan switch) they found it was activating at a HIGHER temperature than a standard VW fan switch would have been! Wouldn't touch one again. Quote Share this post Link to post Share on other sites
bananawhip 0 Posted May 20, 2010 Quote And in fact, after testing by DG Autotech (when I'd fitted a Neuspeed fan switch) they found it was activating at a HIGHER temperature than a standard VW fan switch would have been! Wouldn't touch one again. Ah pants, I've fitted it now but don't think I'll bother with them in the future Quote Share this post Link to post Share on other sites
