VR6_ROB
g60 sump removal
how do i get that damn bolts out on the gearbox side
my sump is leaking pretty bad I have a gti gasket to fit
seems identical
but i cant get the sump off my sockets wont go in the gaps
need a 1/4" wobble extension and /or universal joints
yes a gti gasket is the same..its based on a 8v gti lump
you could get the rubber gasket /windage tray from a mk3 diesel thats a nice upgrade
thanks guys have a go at this tomorrow just hope it is the sump leaking seems to be dripping from there
I don 't think it can be done without removal of the cover plate...
Flexible screwdriver works wonders for this job - easy with the right tools!
Yep, you have to remove the plate (2 bolts). Some sort of flexible extension for the "hidden" sump bolts, and you should be good to go :clap:
I used one like this..
