badgerman 0 Posted June 1, 2010 Hi all, Anyone knowledgeable in engine mount replacement on a G60? Mine are worn and the engine is moving a bit so before I fit my Eaton M90 I would like to replace them. I need to know procedure, things to look out for, approximate time etc. Any help would be appreciated. Regards, Chris Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 1, 2010 think all 4 cylinder cars are basically the same, might be harder to get at things one the front mount on a G60 essentially you just remove the mounting bolts and jack the engine up just enough to slip the mounts out front and rear are fairly easy, gearbox mount can be a little difficult as the fixing bolts are slightly harder to get onto IIRC. If all the bolts are easy to remove it shouldn't take much longer than 30 mins to 1 hr to do the lot. Quote Share this post Link to post Share on other sites
