kevin
cooling fan
just a quick one, after turning ignition off after driving cooling fan comes on and runs for a long time ,like 5 to 10 mins even after a short drive, any help
regards kevin :roll:
It's supposed to do that. Something to do with cooling the fuel vapours after running the engine.
Mine does it on a warm day or if it's been stood still & then switched off.
Got to agree. The fan on my Storm sometimes kicks in after a short drive of a couple of miles, even if the water temp remains reasonably low (ie before it's even reached the half way mark). This can only be a good thing as VR6 motors seem to generate a lot of heat in a small engine bay. Suggest you only worry if the fan doesn't come on.
cheers lads i thought the switch was on the way out ,it's a 16 valve by the way ,i've had a few mk11 valvers and they never did this so was kinda worried
thanks kevin :thumbleft:
