VR6_ROB 0 Posted June 19, 2010 my oil light likes to buzz at me now and again only on corners but today i was having a blast down a country lane and it kept buzzing so i switched the car off for a minute fired it up all was ok if i drive to work steady away its fine i changed the oil pressure switch last week and the oil level is ok could it be a faulty switch??? also what colour wire plugs onto the switch yellow or green Quote Share this post Link to post Share on other sites
krnau 0 Posted June 19, 2010 I had this on my car and it was a faulty oil pump. I had it some time later, and it was because of swapped press switches connectors I think I had it once more due to a faulty switch and then once more due to leaving a disconnected wire so as you see, it may be lots of things; but be careful, if you're really running the engine with low pressure..... :? Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted June 19, 2010 if it was the pump would it just buzz all the time i have been out this afternoon in it and it never did it i might try a new switch first what colour wire should be connected to it ?? cheers rob Quote Share this post Link to post Share on other sites
lion 0 Posted June 19, 2010 mine does this, but im sure its my clocks, if i punch the dials, flash headlights, or hit top of dash it'll stop... dam corrado lol Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted June 20, 2010 mine does this, but im sure its my clocks, if i punch the dials, flash headlights, or hit top of dash it'll stop... dam corrado lol lol does it come on when you go round corners or just when it feels like it Quote Share this post Link to post Share on other sites
lion 0 Posted June 20, 2010 mine does this, but im sure its my clocks, if i punch the dials, flash headlights, or hit top of dash it'll stop... dam corrado lol lol does it come on when you go round corners or just when it feels like it when ever it wants , gonna change the cluster soon lol Quote Share this post Link to post Share on other sites
krnau 0 Posted June 21, 2010 if it was the pump would it just buzz all the time i have been out this afternoon in it and it never did it i might try a new switch first what colour wire should be connected to it ?? cheers rob when mine buzzed, if I pushed accelerator pedal +3000rpm it stopped Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted June 21, 2010 from best case senario to worse. oil used too thin for engine. low oil level in sump.(Is the guide stick holder broken? faulty sender/wiring. oil pump tired. worn engine bearing(Engine rebuild time) remember engine oil thins as it heats so oil pressure will drop.This will be especially evident in an engine with a tired bottom end. Quote Share this post Link to post Share on other sites
