zak
VR6 Gearbox Jumping out of first gear when pulling away
Recently developed a problem with my gearbox where it jumps out of first gear when pulling away. Any ideas on what the problem could be and if it’s a simple fix? Otherwise I’ll be swapping the box out.
Not sure, i had the gearbbox end engine mount out about a month a go and it was in good condition.
I still have this problem and now cannot select 5th gear, i think its a problem with the cable adjustement. How can i check the adjustment?
i hate this one - its totally hit and miss, at least when i adjusted mine. I started by putting the cable bolts in the middle and then trying the gears in turn. I then moved the upper one a few mm forwards and checked again. Then tried it backwards. I put a drill bit in the hole in the lower selector arm and tightened the square end in the middle - i'll come over this weekend if poss, if its not sorted by then.
