steveo29 0 Posted July 1, 2010 got a 8v polo engine im cleaning up , pretty sure the guides are shot just wondered if anyone has any info on diy fitting em ..money is tight atm Quote Share this post Link to post Share on other sites
Gareth_16V 0 Posted July 1, 2010 I replaced the guides in an 8v GTI engine that I rebuilt. New guides for that had to be drifted in and then reamed to the correct size, as they crush slightly when fitted. So to DIY you'd need some sort of tiny hone to open the guides out the fraction required. After you've done the guides you really want to get the valve seats re-cut as the bores in the valve guides will be in slightly different places. Could you not get someone to replace the guides and cut the seats and do the rest yourself? Quote Share this post Link to post Share on other sites
steveo29 0 Posted July 1, 2010 yeah im sure i could get them fitted somewhere, just asking if its doable at home as i have alot more spare time than spare cash lol Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted July 2, 2010 They just knock out and back in,best result is to use a old valve and weld a thick washer onto the them and use it as a punch to knock the new guides is,this method wont need to have them reamed out as they are a perfect fit for the guides(obviously) before fitting in the new guides measure the hight of the guide before you take them out (if they dont have a sleeve to sit against the head) and put the guides in the freezer over night,this will help. Quote Share this post Link to post Share on other sites
