V33DUB
Front Caliper Refurb
Hi all,
I'm going to refurb the front brakes on my 8v.... (256 size)
I have...
Caliper Seal Kit
Caliper Paint
Pads
Goodridge Hoses
Discs are still good
I've read that the caliper slider bolts are not available on their own but that rear Audi calipers are the same and are sold separately. Is there any similar solution for the fronts?
Anything else I should be doing while there?
check the bleed nipples aren't seized, you may need new ones of them
Are these available from VW still, or rather do you know if they're not? If they aren't are any other cars the same? Cheers for the help :wink:
Does anyone know what the 8v caliper is? I believe it's girling but the "54" is the 280mm one isn't is.... does the 256 one have a name as such? Also, which other cars have the same caliper? From what I've read late golf mk2's do? Is this correct? Any others?
Thanks for the help as always
