Roan 0 Posted July 8, 2010 One of the things that's annoyed me since I bought my VR6 is the sloppy throttle pedal. There doesn't seem to be much travel on it (i.e. it sits a lot lower than the clutch & brake pedals) and you can lift it up a good 2 or 3 inches from underneath. It also seems to move laterally as well which doesn't seem normal. I suspect it's blunting throttle response too and I really want to get it sorted. Could the solution be a new throttle cable or can I do anything else to tighten it up? Quote Share this post Link to post Share on other sites
somersetdub 0 Posted July 8, 2010 There should be a clip at the throttle body that allows you to adjust the cable and take the slack out of it- this would raise the pedal and allow you to get full throttle... Quote Share this post Link to post Share on other sites
