Dragon666
Will the ecu show fault codes
hi got issues with my car and need some direction when i put foot down on accelerator it seams to choke wtf is wrong with my car its rather upsettin :(
Cheers mateys yea i changed gasket for er bit under maniforld took all i needed off to get to it cleaned it made it look lovely put it all back together and now when i put my foot down its like something is strangling my engine tried doin car a favour and it kicks me in the teeth :(
Sounds like a case of it not going back together right. Methodically work through everything you did and make sure everything is connected or done up properly, including the HT leads being on right.
