welsh16v 0 Posted July 27, 2010 Im having a total nightmare with my car - its a 1992 'K' 2.0 16v Corrado. Ive been having problems with the fuel pump making a high noise and then cutting out. That seems to have stopped but now the car will start and run fine when cold but once warm it will start to loose power as if there isnt enough petrol going in to the engine!! A garage have tested both fuel pumps and said they work but it must be something to do with the electrics or injection system. (They havent got a dyno to test). Its just had a new Cat so is it something to do with that or Lambda Sensor?? Relay? Im tempted to push this thing off a cliff if I cant sort it out - Can anyone give me some advice? Thanks Quote Share this post Link to post Share on other sites
welsh16v 0 Posted July 29, 2010 Car sorted now - thanks for the advice!! Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 29, 2010 so, what was the problem/solution then? Quote Share this post Link to post Share on other sites
