corrado_sunderland 0 Posted August 16, 2010 anyone know how to get around the issue without having to buy the converter box off jabbasport as there sold out and id rather not pay for one anyway if i could :D Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted August 16, 2010 howay man theres gotta be some-one on here who knows :confused4: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 16, 2010 Why do you need a converter box? Is the tach signal on CAN? If not can you not just pick up the tach signal from the ECU? What engine code is you 1.8T? Quote Share this post Link to post Share on other sites
DANG60 0 Posted August 16, 2010 cant you find out what it is and get something similar from maplins? Surely its just a signal converter Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted August 16, 2010 cant you find out what it is and get something similar from maplins? Surely its just a signal converter thats the problem finding out what it is off some-one who already knows :lol: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 17, 2010 ECU should have an 80 pin connector. Engine speed is off Pin 6. Wire should be a 0.5mm green/brown. Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted August 17, 2010 ECU should have an 80 pin connector. Engine speed is off Pin 6. Wire should be a 0.5mm green/brown. cheers bud ill have a look into it, im havent got a clue why its needs one but i was told it defo does :confused4: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 17, 2010 ECU should have an 80 pin connector. Engine speed is off Pin 6. Wire should be a 0.5mm green/brown. cheers bud ill have a look into it, im havent got a clue why its needs one but i was told it defo does :confused4:[/quote:2h1jni48] It might well need the signal to be amplified. I don't know what the Jabbasport adapter is, but I know that MSD make an adapter, that could be an alternative. Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted August 17, 2010 ill have a look on the net thanks bud :thumbleft: any links to site as i had a look there and couldnt fiind anything other than the main products they do Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 17, 2010 This may help... clicky Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted August 18, 2010 This may help... clicky yeah it has thanks, i started reading that last nite when i was out of it and it completely blew me head off and i gave up :lol: got the part number for rite job now though ill have to try find a uk source of em :thumbleft: Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted October 22, 2010 got a jabbba converter in the end and its all sorted :grin: Quote Share this post Link to post Share on other sites
