Wullie 1 Posted August 18, 2010 Went to do some work on the car today and when I went to take the injectors out they only pulled so far then stopped. On closer inspection the large O ring is slipping out of the groove on the injector and sticking in the manifold then when the small O ring reaches it the whole caboodle sticks there. Should I just give it a good yank and chance breaking something or is there anything else I could do. Don't feel like taking off the manifold as the car goes in for it's MOT Friday. Any suggestions welcomed. Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 18, 2010 I'm sure I used a bit of WD40 to persuade them to come out, it is a pain when they do that, I'm sure with a bit of lube and some jiggling everything will be fine :norty: Quote Share this post Link to post Share on other sites
Wullie 1 Posted August 18, 2010 I'll get out the WD40 and practise my wiggling :) Quote Share this post Link to post Share on other sites
dannyboy 0 Posted August 18, 2010 bit of 14 guage wire helps alot. bend a hook onto the wire and bit wd40 and out they come had the same prob on my mk2 gti 16v when i changed them.made it alot easier hope it helps! :) Quote Share this post Link to post Share on other sites
