dan 0 Posted August 20, 2010 Hi all, I'm fitting new top mounts to my VR & would like someone to have a look & tell me if I've got it right. I've fitted the metal bearing between the top red cap on the strut & the mount itself. Then I used the nut with the lip to fix the mount & bearing to the strut. Another question, is the spring the right way up? Thanks Quote Share this post Link to post Share on other sites
aide 0 Posted August 20, 2010 where's the larger metal 'saucer' shaped thing? from memory my order from engine bay down is: nut metal saucer ----- bodywork tower ------- nut washer long cylinder with top mount surround spinning bearing large circular saucer spring retaining cap (plastic red thing) spring \/ Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 20, 2010 Yep, that's done correctly. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 20, 2010 where's the larger metal 'saucer' shaped thing? from memory my order from engine bay down is: That doesn't go on until it's been fitted to the car Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted August 20, 2010 That cup and nut is only there to stop the strut falling out when the car is jacked up (or airborne!) Quote Share this post Link to post Share on other sites
aide 0 Posted August 20, 2010 Yeh guys realise that! I'll get a.photo of the saucer thing I mean later. Quote Share this post Link to post Share on other sites
dan 0 Posted August 20, 2010 Thanks for the replies guys, I still have the top saucer & 22mm nut to go in after I fit it back into the car. Think I have everything in the right order then :D Anyone know about the spring? The spring can go in either way but I decided to put the fatter part towards the top just in case it fouls the wheels or anything. Then when I look at it I'm thinking the spring is more compressed at the fatter end so maybe it should be at the bottom for stability :shrug: Quote Share this post Link to post Share on other sites
aide 0 Posted August 20, 2010 ignore me completely :) i've just checked mine and i have it wrong! Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 20, 2010 Not sure on this - but to me it would make sense to have the wider part of the spring at the bottom???? Quote Share this post Link to post Share on other sites
dan 0 Posted August 20, 2010 ignore me completely :) i've just checked mine and i have it wrong! :lol: you have it right in the post above, the only things missing from my pic is the top saucer & nut. I'll put those on when fitting to the car. The main thing I was worried about was the metal bearing... I wasn't sure if it went above or below the rubber mount. But now you have all confirmed that it goes between the rubber mount & the red metal cap thanks all :D Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 20, 2010 This pretty much sums it up: nr5 beiing that red cup :) Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 20, 2010 off topic - but where about in Ireland are you from ? :) (Used to travel a bit around down there - never saw a C around there though)....:) Quote Share this post Link to post Share on other sites
dan 0 Posted August 20, 2010 off topic - but where about in Ireland are you from ? :) (Used to travel a bit around down there - never saw a C around there though)....:) Hi Mawrick, I live in a town called Strabane, it's North West of the country, on the border between Co. Donegal & Co.Tyrone :D Thanks for the illustration but I have no.7 and no.8 the other way round :shrug: Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 20, 2010 off topic - but where about in Ireland are you from ? :) (Used to travel a bit around down there - never saw a C around there though)....:) Hi Mawrick, I live in a town called Strabane, it's North West of the country, on the border between Co. Donegal & Co.Tyrone :D Thanks for the illustration but I have no.7 and no.8 the other way round :shrug: Ok - Mostly spend my time in Galway - although traveled most of the country :) Then you have them mixed - the nut should hold the bearing - not the rubber thingy ;) Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 20, 2010 Also if you have these type of nuts I think they are not right: it should look more like nr 3 here: Quote Share this post Link to post Share on other sites
dan 0 Posted August 20, 2010 Guess what... I do have the nuts with the lips on them & I now have them fitted back on the car :( I think I'll take them out of the car again, lay all the parts out on the floor & post a pic of them on here. Thanks again all :salute: Quote Share this post Link to post Share on other sites
aide 0 Posted August 20, 2010 there you go nr 6 on that picture is the large saucer i'm talking about :) but you only run that on the standard set up i think. the thing i found when putting mine on is the turny bearing thing didn't sit on the plastic spring plate very well, in fact there was a gap between it and the top mount which kinda defeats the purpose, maybe it doesn't make a difference! Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 20, 2010 yea - you can always check with someone else - but I also bought those nuts, and a mechanic with 30+ years experience told me I would be better of using the ones without the "wing" - as the wing doesn't go thru the hole of the rubber thingy - and the nut is pretty much there for holding pressure on the bearing. The rubber thingy should be "free" anyway :) Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 20, 2010 there you go nr 6 on that picture is the large saucer i'm talking about :) but you only run that on the standard set up i think. the thing i found when putting mine on is the turny bearing thing didn't sit on the plastic spring plate very well, in fact there was a gap between it and the top mount which kinda defeats the purpose, maybe it doesn't make a difference! yea, nr 6 is only for "normal" setup - the red cup (or purple on the KW) replaces this one ;) Quote Share this post Link to post Share on other sites
