Mawrick 0 Posted August 27, 2010 Anyone know how the VR6 FPR works - and can anyone confirm that the "filter" part is supposed to "travel" on the "rod" part of the FPR - the one I replaced the filter part seem to stay stuck hanging onto the main "lump" of the FPR. IF that sentence made any sense....lol....... Quote Share this post Link to post Share on other sites
KipVR 1 Posted August 27, 2010 hope this helps! http://www.howstuffinmycarworks.com/Fue ... lator.html Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 27, 2010 a good guide!, thnx. btw - any idea is that "filter-ring" is supposed to be loose on the "rod" or supposed to sit in one position ? the thingy with the "black" ring: Quote Share this post Link to post Share on other sites
Yandards 0 Posted August 28, 2010 Filter ring (o ring seal) need to stay in place on the rod, these newer style of FPR are a very neat compact design and both fuel into the rail (the large filter element area) and fuel return 'rod' need to be sealed from the outside and each other. If you are struggling to fit the FPR then try lubing the o ring seals with some brake fluid. Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 28, 2010 Filter ring (o ring seal) need to stay in place on the rod, these newer style of FPR are a very neat compact design and both fuel into the rail (the large filter element area) and fuel return 'rod' need to be sealed from the outside and each other. If you are struggling to fit the FPR then try lubing the o ring seals with some brake fluid. no trouble fitting it - but the spare one I had the filter ring is able to move along the "rod" part, where the one I took out the filter seem to be stuck in one place - was just wondering what was "right" - also could a bad vacuum hose on the FPR cause it to operate wrongly at startup maybe?. Quote Share this post Link to post Share on other sites
Yandards 0 Posted August 28, 2010 Filter ring (o ring seal) need to stay in place on the rod, these newer style of FPR are a very neat compact design and both fuel into the rail (the large filter element area) and fuel return 'rod' need to be sealed from the outside and each other. If you are struggling to fit the FPR then try lubing the o ring seals with some brake fluid. no trouble fitting it - but the spare one I had the filter ring is able to move along the "rod" part, where the one I took out the filter seem to be stuck in one place - was just wondering what was "right" - also could a bad vacuum hose on the FPR cause it to operate wrongly at startup maybe?. No the filter element should be fairly well stuck be as it sits on a lip in the fuel rail it will hold it in place ok and it is 'just' a filter element. As for the start-up problem, no it won't be the FPR vacuum hose as that would cause poor running regardless of cold or hot. Quote Share this post Link to post Share on other sites
