Roan 0 Posted September 7, 2010 When I plug in my vagcom cable into my VR6 (OBD2 type connector rather than earlier 2x2 type), the LED doesn't light up (ignition is on) and VCDS tells me that the cable isn't plugged into the car. Is there a fuse for the OBD port? I have a feeling that my electrical short (I can't put a fuse in number 21 without it blowing straight away) might be the culprit.. and I can't find what is causing it either :mad2: Quote Share this post Link to post Share on other sites
RW1 0 Posted September 7, 2010 No there isn't. Two wire routed via a connection link* directly onto the engine ECU. * gear shift 16 way socket's two signal wires are connected to a terminal block directly behind the cubby hole inside the lower centre dash. Take off the fuse shelf then the driver's under shelf. It will visible on top of the tunnel. Fuse 21 Cig. Lighter Interior Light & Reading Light Illuminated Sun Blind Mirror - Passenger Boot Light Dash LCD Instrument Panel . Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted September 7, 2010 or just give the 2x2 its own power and earth supply? Quote Share this post Link to post Share on other sites
