adolf1976 0 Posted September 11, 2010 hi car was due mot yesterday but abs light came on and stayed lit on thursday so had to cancel. Now off the road :( is there a way of flashing the error codes or do i need vagcom. I used to have a bmw e30 and you could join two of the pins together on the service plug and the codes would flash out on the light. Car is a 2l 16v Quote Share this post Link to post Share on other sites
adolf1976 0 Posted September 12, 2010 have read on a few sites that they do this on a g60 in usa. They put a jumper between the abs wire and earth and the abs light flashes the code. Anyone ever done it or know what the wire diagram for the fault reader is Quote Share this post Link to post Share on other sites
JMC 0 Posted September 12, 2010 Chances are it's a duff sensor. If you have a multimeter, you can check that out yourself in about 5 mins. Use the search on here, it's been covered loads of times. Quote Share this post Link to post Share on other sites
