ww-promo 0 Posted October 21, 2010 Hi, I have recently had some knocking comming from the rear end [passenger side] when reversing out of the drive or turning into say a car park over a small pavement step etc. Untill tonight, I had just pulled out onto a dual carriageway and I heard a bit of a clunk, then the C seemed to wobbly left to right! :shock: It seemed like the rear end was steering. After :censored: :censored: :censored: alot I very quickly & slowly pulled over and abandoned her :( . Can anyone please help me. Would it be the rear axel bushes? I did notice that the rear wheel had rubbed on the inside, so somthing has moved, alot! Thanks in advance! Oli Quote Share this post Link to post Share on other sites
mimjed 0 Posted October 21, 2010 bugger. suspension could be coming loose, axle itself coming loose. wouldnt have thought bushes would have gone that bad that quick, but you wont know until you have a good butchers underneath in the day light. Quote Share this post Link to post Share on other sites
Jim 2 Posted October 21, 2010 Could be any number of things. Best get it recovered and inspected! Luckily nothing on the rear of the car is THAT expensive to fix to be honest :) Quote Share this post Link to post Share on other sites
ww-promo 0 Posted October 21, 2010 F :censored: K it! Sure this ones cursed! I dont really know what Im doing so will have to get my garage to come and collect her. Wheres that bus stop again? :( Quote Share this post Link to post Share on other sites
ww-promo 0 Posted October 21, 2010 Could be any number of things. Best get it recovered and inspected! Luckily nothing on the rear of the car is THAT expensive to fix to be honest :) I'm liking the sound of that! Will call first thing. Quote Share this post Link to post Share on other sites
carrots 1 Posted October 21, 2010 could just be a bearing Quote Share this post Link to post Share on other sites
coullstar 0 Posted October 21, 2010 Are you not in the AA or RAC? Should be something relatively simple to fix. Is the wheel sitting at more of an angle then usual? Was the other wheel still in the same position? Have the rear wheel bearings been looked at recently? Quote Share this post Link to post Share on other sites
mimjed 0 Posted October 21, 2010 normally hear the disc suffering if the wheel bearing is bad Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 21, 2010 I'm going for rear shock through the upper plate because of corossion... Quote Share this post Link to post Share on other sites
ww-promo 0 Posted October 21, 2010 Are you not in the AA or RAC? Should be something relatively simple to fix. Is the wheel sitting at more of an angle then usual? Was the other wheel still in the same position? Have the rear wheel bearings been looked at recently? No im not in the AA or RAC.....after driving Corrados for 6+ yrs I've only ever needed a tow once by my dad as my Alt went. So thought it wasnt worth it! I dont know to be honest. Not sure if the bearings have been done. No paper work for it. The wheels have not been humming. It looked pretty normal, but I did give it a good shake and there was plenty of play on the rear. Angle wise; it seemed normal. but was dark and had no touch. Quote Share this post Link to post Share on other sites
ww-promo 0 Posted October 21, 2010 I'm going for rear shock through the upper plate because of corossion... Sounds like were taking bets! :D If that was the case, is it just the suspension that would be knackered? Quote Share this post Link to post Share on other sites
ww-promo 0 Posted October 24, 2010 Finally got her to the garage today on a top loader. The rear wheel was all over the place. Should get the verdict tomos. I think you might be right about the suspension! Quote Share this post Link to post Share on other sites
ww-promo 0 Posted October 24, 2010 PS. Does anyone have a set of coilovers going? Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted October 24, 2010 I'm going for rear shock through the upper plate because of corossion... if that's the case my money's on the driver's side because of the crap collecting around the filler pipe :( Quote Share this post Link to post Share on other sites
ww-promo 0 Posted November 8, 2010 Turns out that the last garage to touch my C change the rear bushes but did not tighten the bolts up!!!!!! WTF! One bolt was. Completely missing, one was cracked, I presume due to the xs weight & one was loose. Won't be going back there in a hurry! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 8, 2010 Better give them a good write up then .. ;) FWIW it's a really weird feeling. I had two well worn out rear wheel bearings once and that was enough to make it feel rather like a shopping trolley.. Quote Share this post Link to post Share on other sites
