Roan
Seat Ibiza FR 1.8T brakes...
I recently picked up a set of calipers, carriers and discs for the above, thinking they would be the same as the late Golf VR6. The discs are 288mm, but the calipers and carriers look identical to the standard Corrado 280mm brakes. On closer inspection, the calipers are indeed stamped as Lucas/Girling G54 :confused4:
If the calipers are Lucas/Girling G54 the same as the 280mm standard Corrado ones, how can they have been fitted to the larger discs on the Ibiza? :confused4:
The only part numbers I can see on the top of the calipers is 32327385/F and H212...
Same as these on ETKA:
http://www.vagcat.com/epc/cat/se/IB/2002/254/54/4735407/
