Supercharged 2 Posted October 23, 2010 Thought I'd stick a post up about the above as I'm currently borrowing it from Yan and couldn't find anything on here already. He used it on my car the other week while I was doing other stuff but I had chance to use it myself today - superb bit of kit! It basically works like an Easi-bleed but hold more fluid so you don't need to keep messing around topping up and is very well built with proper connectors etc, it also runs off the battery using it's own built in compressor rather than a spare tyre like the Gunsons kit. Very impressive and also made in Scotland http://www.liquid-levers.com/cbb.htm http://www.liquid-levers.com/pdf/cbb.pdf Quote Share this post Link to post Share on other sites
Andy665 0 Posted October 24, 2010 You have to be bleeding a lot of brakes to justify that expense Quote Share this post Link to post Share on other sites
Yandards 0 Posted October 25, 2010 They were selling them on fleabay for about £135 a few years ago when I bought it. You should be changing brake fluid every 2 years and for a non-ABS car it's 500ml per corner and ABD is 600ml per corner IIRC. It does make the job nice and easy and I have done a lot of cars with it now. Not only that it's the sort of tool I would expect to last me a lifetime. Quote Share this post Link to post Share on other sites
