nickeboy
replacing hand brake cable
could any one give me a quick guide to replacing the hand brake on y 93 vr6, im sure it is pretty easy but there is always a clip that hold something somewere i dont see untill i have broken it!
it goes in the car is it under the carpet?
thanks
nick
If you remove the plastic centre tunnel you'll see where the cables attach to the hand brake lever mechanism, just undo the lock nuts from the end of the cable and you should be able to pull them out from underneath the car. There's a couple of clips that hold the cable sheath to the rear beam if I remember correctly. On mine the inside of the guide tubes that go through the floor was a bit rusty so it was a bit of an effort to get the cables out but they do fit.
