VR6_ROB
rear end noise
i have had a look in the search cant find anything
not clued up on the corrado much recently when i turn hard usually left its make a rumbling noise on the rear as if something was rubbing
its now started to do it when i turn right, fine in a straight line
i have jacked the car up spun the wheel everything seems fine i have tried to move the wheel up and down
and side to side no play in it, i have looked underneath incase the wheel was rubbing on something everything is fine exhaust is tight and not catching
anybody had this problem its really annoying and its getting worse
rob
it sounds like one or both of your wheel bearings are worn, you cant always feel if they are gone, by spinning them as they cause a small score /discoulouration in the bearing race, the bearings are about 15 quid a side. worth doing for peice of mind,
or you brake pads could be wearing thin, check the pads and disc have plenty of meat on them!
