marshall2672 0 Posted November 24, 2010 i have a problem with my 2.0 16v corrado it starts and ticks over but idle is a bit rough as soon as i try to rev it it cuts out and struggles to start again.i've checked the pump and filter and seem ok.now im running out of ideas Share this post Link to post Share on other sites
easypops 8 Posted November 24, 2010 Sounds like a possible air leak, check all the pipes around the throttle body,the isv etc and check the 2 small hoses under the rubber connection to the TB are connected........then try cleaning you isv........also unplug the 5th injector.........and check the wiring for the throttle potentiometer......then its onto the MAF or you could try reading these :lol: viewtopic.php?f=1&t=96214&hilit=2.0+16v+maf viewtopic.php?f=1&t=62564&hilit=2.0+16v+kangaroo viewtopic.php?f=1&t=84474&hilit=2.0+16v+idle viewtopic.php?f=1&t=84789&hilit=2.0+16v+idle viewtopic.php?f=1&t=83795&hilit=2.0+16v+idle Good Luck :salute: Share this post Link to post Share on other sites
VR6 0 Posted November 24, 2010 Yeah, done to death I think ... thanks Popsy. Share this post Link to post Share on other sites
