philvr6
VR Died on me
Driving to work this morning and my 95 VR6 cut out suddenly. :(
Tried to start it but with no luck.
ended up being towed back home
Lots of battery power but fails to start.
Decided to
Removed the two fuel pipes from the injector rail , turned the engine over but no fuel came out of any of them. :confused4:
Could this mean a failed fuel pump,a blocked filter,a blown fuse, a faulty relay,?????
Looking for any suggestions here???? also need to know where the fuel pump is exactly.....Is it in the boot.above the fuel tank????.unlike the Golf GTI which is underneath the car...Also does it have a lift pump inside the fuel tank ???? :help:
If it does turn out to be the fuel pump, and it sounds like it, then for your sake i hope its not got a lot of fuel in it, horrid job changing the pump out if theres much fuel in the tank, as I found out... :(
Definitely a good idea to try the relay first though.
Good luck!
P.S. skinned knuckles and petrol f*****k stings!
Job done :clap:
It was the fuel pump after all
Did all the relevant checks.... fuse ok,relay ok, voltage to pump ok. The final test was putting 12v direct from the battery to the pump connector in the boot and it was lifeless.
The tricky bit was twisting the pump anti-clockwise to release it from the bayonet fitting in the tank. I didn't want to put too much pressure on it incase I damaged the sender unit , but it needed quite a bit of torsion to get it released and as it happened the fuel level was low anyway.
Simple installaton and she fired up a treat
Check fuse 18
Check relay J17 position 12 or bottom row far right
:salute: thanks for the help and comments
