vagingit.co.uk
different shifter towers/cables?
This is about my Jetta, not the Corrado, so ope you dont mind me asking :shock:
Im doing a G60T conversion into my Jetta, using a Corrado G60 engine and box. The only thing is, I dont have any of the gear change mechanism - shifter,cables,pedal box, master cylinder
Do need anything else?
And, do I have to use Corrado G60 cables/shifter etc? Or can I use others, as its not easy finding all this from a Corrado G60
any cable change setup will do, mk3 golf GTI/VR is basically the same as Corrado, and a mk4 golf setup could be used (and is a better design, need matching box tower)
most options will require some modification to fit at gearlever end, especially mk4 setup, but all doable, think you'll find a corrado gearlever is too short for a golf/jetta for a start anyway
