AlgarveVR6
Engine Swap
Ok, got to swap my engines next month.
Looking for tips, helpful advice, things to do, not to do
Its a VR6 dizzy at the moment, and putting in a VR6 coil pack.
Is it best to remove wings and front valance etc.
Will the engine just slide forward if I do.
Is it better to lift it, or any ideas
Any help would be much appreciated
Thanks everyone
Dic :D
its fairly straight forward. Remove the front end ie bumper rad and slam panel. disconnect all pipes and wires and driveshafts fro the box. Engine will slide out of the front, no need to lift the car or move it.
Only tips I can think of is that the power steering sysem can be left all connected, saves on bleeding the systems later on. so remove the PS pump from the block and route the pipes out of the way during the swaps.
Gearbox can stay on the engine block during the removal, makes its allot easier to change the box off the car than on!
No need to remove wings.
No idea how straight forward a dizzy to coilpack conversion is, but I would presume the looms will need changing? if so change the looms while the engine is out.
When refitting the engine, place on the engine mounts but dont torque down the bolts, just finger tight. Start up the engine (once all plumbed up etc) to allow the engine to settle into position, then switch off and torque all mounts up.
good luck
If your confident with vr6 engine timing you can simply swap engine looms, and ecus, swap the end plate that the dizzy/coilpack bolts to and swap cams, this way your engine can stay sat were it is an should only take half a day, you will need help getting the loom past the bulkhead.
Otherwise just swap the whole lot As you plan following the steps in the above posts
thanks quicky you make it sound so easy
Erny, it's the other engine I want in my car, so not really necessary to leave engine in
many thanks chaps
will maybe take some pics too
:help:
Small tip that will save you so much hassle and time when removing and refitting the driveshafts.
Buy a driveshaft removal tool from ebay or wherever. It's simply an extra long spline (M10) allen style shaft that you can fit onto a rachet. The subframe/engine mounts and calipers are designed in such a way that you can loosen the bolts with only the wheel off and without even going under the car.
Something like this http://cgi.ebay.co.uk/Laser-2897-Spline ... 2a089421bd .
It's worth every penny.
thanks Jamie
Just ordered one now and they can post here too.
Bonus. Any more tips appreciated. Not done engine swap on this before
Thanks
Good luck! It's actually not too hard once you get your head around it and realise it's just a big mecanno set.
If you want I could list through the tasks and suggest an order to help get you started? Wouldn't be comprehensive, but hopefully cover most things. It's always easier if you know roughly what to be doing, rather than have to start from scratch. Let me know if that'd help,
J
I now know why I use these forums.
It's people like you who make it worth while
The list would be fab
If you ever come to the algarve then there would of course be the obligatory case of beer for you
Cheers Jamie
ooooooooooo soooooooooooooooooo happy
running well, pulling like a train and sounding like only a vr6 on full chat can.
few things to finish like internal panels and swapping rear seats.
sunday is polish day.......
:clap: :clap:
