stu37
Changing Gearbox mount vr6....?
Hi guys just wondering how hard it is to change the gearbox mount on the VR it looks to me to be a simple... support engine, unbolt, jack up and replace...? Is this the case or am I missing something..? Ant opinions would be greatly recieved. :)
thats about right. I found i had to rotate the mount to get access to teh bottom bolt, which was a bit fiddly. Access as with all corrado jobs, is perhaps the only issue you'll encounter. Soak the mounting bolts in penetrating oil the night before, just in case.
Did this last week took 30 minutes, only thing i did different was having to jack the car on the sills to get the trolly jack under the gearbox as mine has been lowered.
