JumboJimboG60
ADVICE ON SUPERCHARGING MY VR6 PLZ :D
HI GUYS,
IM THINKIN OF CHARGING MY VR6 AND WOULD LIKE SOME ADVICE ON MAYBE WHERE TO GO AND GET IT DONE,
AND ALSO WHAT ELSE IM LIKELY GOING TO WANT TO UPGRADE OR NEED TO INSTALL AND WHAT NOT
CHEERS
JIM
You will need:
A supercharger with associated pipework and mounting bracket- Rotrex or Vortech
Larger injectors (mine were Bosch 315s)
Air filter
ECU Remap
ARP head bolts
If your engine is healthy enough, you can get away with just these.
Non essential but recommended:
Chains and headgasket (if not done recently)
Oil cooler
Water injection
uprated radiator fans
Cams (DG Autotech, Schimmel, etc)
possibly a new fuel pump
If you are going down this road, make sure that your engine is in as good a state as possible before starting, as things will go pop, bang and boom if you stick another 100 or so bhp on top when they've already done 100k miles!
All sage advice.
It's worth adding that if you plan on exceeding 12psi, especially with the larger Rotrex, it's a good idea to lower the compression ratio.
Check out B15 VWC's Rotrex thread. Easily the best S/C VR6 I've seen to date. Tonnes of power and built to take it. It might give you some inspiration.
Plenty of other guys have very nice Vortech installs too. Not as savage as the larger Rotrex, but pretty effective all the same.
