flusted 0 Posted February 20, 2004 Hi Im new to the corrado scene and ive just bought a gplate 16v.I lost my keys the otherday and had to break the door handle to get in :cry: Are all corrado doorhandles the same or am i right in thinkin they changed them on the later ones???Will passat ones fit??? Please help as my mot is about to run out and theyl fail it on the handle Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted February 20, 2004 PASSAT ONES CAN BE USED IF YOU USE THE MECHS ASWELL, there is lots of information on here try doing a search with passatANDhandles, also the later door handles will fit as ive seen the late vr6 type handles on a 91 g60,, bazgreener has done it on his, hope this helps, :roll: Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 20, 2004 By the way - most people I've heard of are using the passat *rear* handles for that de-locked look, but if you have success using the passat *front* handles (with locks), we'd all be interested to know that they fit. No-one can think of a reason they wouldn't, just that AFAIK no-one's tried it.. Quote Share this post Link to post Share on other sites
G60Dan 0 Posted February 20, 2004 Passat a handle conversion as below: http://the-corrado.net/.archive/forum/viewtopic. ... at+handles Drivers Handle 357 839 206 Drivers Catch 357 839 016B Passengers handle 357 839 205 Passengers Catch 357 839 015B Dan Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted February 20, 2004 the passat locking handles aren't that much cheaper than a corrado one so it aint worth doing that if its a cost thing. get the rears and the locks n fit um and screw out the white adjuster a couple of turns. test the lock. if it locks and you can still open the door screw it back in a fraction until this stops. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 20, 2004 GazzaG60 said: the passat locking handles aren't that much cheaper than a corrado one so it aint worth doing that if its a cost thing. Ok, but I was under the impression that the passat handles don't die like the Corrado ones do. Maybe I'm wrong, but if they're going to last much longer (like the life of the car would be nice), then it's got to be worth paying the cash, if that's what it takes. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 20, 2004 It's because the actuator arms on the Passat handles are longer than Corrado ones, hence requiring the passat latches aswell. Think of it this way....Passats actuator arms resemble a half clenched fore-finger, Corrado ones are almost a fully clenched fore-finger! Passat handles will 'miss' Corrado latch lever but they will work-ish....just not as nice and smoothly as with the proper kit. My advice is to just use blinkin Corrado ones.....with plenty of grease......and you'll not have a problem. Lockless handles are fine until the central locking fecks up....and then what do you do? The differences in Corrado handles are nothing more than aesthetic....late ones have a ridge around the lock, early ones don't :D They are exactly the same internally. K Quote Share this post Link to post Share on other sites
flusted 0 Posted February 20, 2004 kevhaywire said: The differences in Corrado handles are nothing more than aesthetic....late ones have a ridge around the lock, early ones don't :D They are exactly the same internally. K Thats wot i wanted to hear :D I ve sourced a late handle but needed to know if it will definatly fit THANKS EVERYONE Quote Share this post Link to post Share on other sites
paulg60 0 Posted February 27, 2004 thats why i got one with a ridge on and one without :) Quote Share this post Link to post Share on other sites
Henny 0 Posted February 28, 2004 paulg60 said: thats why i got one with a ridge on and one without :) Snap (until I fit the passat ones sat in my garage! ;) ) Quote Share this post Link to post Share on other sites
flusted 0 Posted February 29, 2004 Ive managed to source some passat rear ones now with latches so il let you know how i get on when ive fitted em Quote Share this post Link to post Share on other sites
