carrots
knocking due to wishbone hitting roll bar
ive had a knock from the front i can not cure,now i think ive found the prob.put it on a ramp today and ti looks like the os wishbone is about 1mm off the roll bar.so any little bump causes them to knock together.anyone else got this prob.is there a cure
or it could be the wrong or poorly made drop links, I had to space the link washer on one to give plently of clearance too.
the drop links are unipart,could it be because the car is lowered.mite try and space them as you said.how did you do it.cheers
depends on the design of link, mine could take an extra big washer or two to move the rubber bushes away from the 'eye' a few mm
