dubberbaz
non starter 16v
hi i have a corrado 16v 2.0i 9a engine it ran out of petrol and now wont start i have put £20.00 of fuel in it primed the pump and it started but cut out as soon as i touched the throttle and now wont start again just asking if anyones got any ideas as the wife told me to get rid but i have parked at my mums so she thinks i have lol
i dont want to spend loads on it as i could get a new engine for £100-150
i have a spare metering unit and also a spare isv and ecu that i am going to try
just asking if anyone has had problems like this and how they fixxed it
can you hear the fuel pump prime? have you got fuel up to the metering head?
how much fuel did you put it? if it went completely empty , i would a least put 3 gallons in, 3 jerry cans.
also check all of your vacuum pipes to see if they are split or come adrift.
probably some crap from the tank got sucked through the pump and it now blocking one of the lines as you ran it to empty. I'd recommend checking the lines from the tank are clear and maybe flushing the pump through with some good petrol.
