Abdul 0 Posted February 15, 2011 Hi guys, need a set of these in my life.... Anyone? Thanks Quote Share this post Link to post Share on other sites
monzablau16v 0 Posted February 15, 2011 i was looking at buying some myself...then i read they are just stick on and not heated. That kinda drowned the idea for me personally! Good luck though, they do look nice. Quote Share this post Link to post Share on other sites
JMC 0 Posted February 15, 2011 Yeah, but you can buy stick on 12v heating elements for about 8 pounds from Conrad Electronics and then they're heated ;) Quote Share this post Link to post Share on other sites
monzablau16v 0 Posted February 15, 2011 Yeah, but you can buy stick on 12v heating elements for about 8 pounds from Conrad Electronics and then they're heated ;) ohh, sounds interesting. Have you got a direct link or product number on the website. Did a quick search but didnt find anything on http://www1.conrad-uk.com (assume that is the correct website?) ta Quote Share this post Link to post Share on other sites
Abdul 0 Posted February 16, 2011 Cheers dudes, has anyone got one though? Quote Share this post Link to post Share on other sites
JMC 0 Posted February 16, 2011 ohh, sounds interesting. Have you got a direct link or product number on the website. Did a quick search but didnt find anything on http://www1.conrad-uk.com (assume that is the correct website?) ta This is lifted from another thread of mine.... "For replacing the heating elements I used an aftermarket self adhesive 12V heating foil. If you search for a company called Conrad electronics online, they are uk based. Go to their search and put in "Heating foil 100x65 mm pair" and you should go straight to the page. With mine they heat the central portion of the glass, which is good enough for me. They do make a larger one "Heating foil 130x70 mm pair" but it uses more power, and I didn't want mine heating all the way to where the adhesive was holding them on to the frame. These bigger ones might work better with a resistor in series to lower the voltage and reduce the temperature rise a bit (even the small ones get hot)." Quote Share this post Link to post Share on other sites
Abdul 0 Posted January 24, 2012 Re bump on this a year later. Quote Share this post Link to post Share on other sites
Philuk 0 Posted January 24, 2012 Are the ddi mirrors for Rhd? I thought they were M Lhd and the drivers side one was all distorted? Quote Share this post Link to post Share on other sites
iR6 0 Posted January 24, 2012 Ive often looked at these, nice and subtile :) Site says- "Both driver side and passenger side are wide angle. Therefore Corrados which are right hand drive ie. in the UK can also utilize them." I would be 100% interested if a group buy was arranged for these. Quote Share this post Link to post Share on other sites
