unitfight 0 Posted February 25, 2011 For some reason, the red coolant light on my dash has started flashing and im a bit stuck?? which sensor on the engine would controll this? for some reason, it came on after i fitted a new ecu chip, could this be related? Quote Share this post Link to post Share on other sites
firecracker 0 Posted February 25, 2011 i reckon you've knocked the temp sensor plugs into the expansion bottle Quote Share this post Link to post Share on other sites
g60 dave 0 Posted February 26, 2011 i think you caught the level indicator plug on the expansion bottle Quote Share this post Link to post Share on other sites
carrots 1 Posted February 26, 2011 you havent got oil in water have you Quote Share this post Link to post Share on other sites
SIMONG 0 Posted February 26, 2011 prob be the bottle itself, mine did this a while ago. was worried i was losing coolant. but it was just the sensor in the bottle. new bottle from VW was about £12. Quote Share this post Link to post Share on other sites
Diesel Junior 0 Posted February 26, 2011 Just had the exact same problem. Are you losing water? If not i bet its the sensor, have a look inside the expansion tank, can you see the two wires going into the coolant? I couldnt see mine as they were so covered in poo so took the expansion tank out, got it as clean as i could with tap water, degreaser etc then put it in the dishwasher (but not the cap......) at 65 degree cycle, all crap gone, end of problem. If you are not losing water, odds on its the (crappy) sensor.....BTW, VW told me it was new radiator time €€€€€€€€...... Quote Share this post Link to post Share on other sites
unitfight 0 Posted March 2, 2011 i have a different expansion tank with no sensor. im not overly sure where the sensor is to be honest? has been fine for the last 2 years as it is Quote Share this post Link to post Share on other sites
unitfight 0 Posted March 2, 2011 sorry. water temp, pressure and level is all spot on Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 2, 2011 The plug for the original tank will be bridged then and you must have knocked it fitting the chip - should be around the same area. I would find it and also fit an original tank back on - very cheap from VW for a new one. Quote Share this post Link to post Share on other sites
unitfight 0 Posted March 4, 2011 cant find an electrical connector anywhere!! im thinking maybe it was cut out of the loom, spliced together then taped up or something! out with the dash bulb it is then!!! Quote Share this post Link to post Share on other sites
